Hello Experts,
We have a PPPoE server which has a traffic of 950Mb, its a CCR1036, how can we upgrade the ports? what is advisable for Mikrotik? Bonding or is there anything else to use to combine traffic.
Thank you.
Hello Experts,
Thank you.
How many pppoe sessions ?
Connection Tracking is on or off ?
CPU load ?
check % usage of most loaded CPU core at peak traffic hour to estimate possible remaining processing power
I don’t think OP asked about utilization of CPU etc, but port speeds.
Depending on which CCR you have, you can change PPPoE to the SFP+ port which will give you 10Gb/s capacity, if you have the SFP only model, that will at least give you 1.25Gb/s for now.
Else I think you need to split traffic from different areas into separate VLAN’s/interfaces
I ask about cpu utilization because that’s how i will suggest preferable method.
