Individual port stats on RB750UP
Is it possible to enable individual port statistics for each port (2 to 5) on an RB750 ? Out of the box ports 2 to 5 are bridged and I can see stats collectively for this bridge but not individual ports.
I have a flat 192.168.9/24 network with approximately 25 devices. I am proposing to use the RB750 to connect two access points and a wireless bridge (to another office 200 yds away) and it is important to keep an eye on the bandwidth of these devices.
Regards
Gavin
They are probably switched. Remove master ports from each slave port and put all ports into bridge.
Putting all the ports in a bridge will kill the L2 switching performance because everything will hit CPU.
What ROS version are you running. I believe in the latest 6.x version they added per interface stats even when ports are in a switch group.
It has only 100m ports so switching / bridging with fastpath or at least without bridge firewall will be without noticeable difference. Sure, upgrade is recommended and then you can test which mode is better for you.
