Indoor Case RB333/433
Hi
When I use 3 minipci card with MMCX connector then indoor case is to small
When MT is begin produce highter indoor case ?
I dont beleive MT makes cases… Pacific wireless does and others… However you are going to need a good size one if you are going to use all 3 slots on the Rb433… JP gave me a link to some that work but i dont have it at the moment… Looks around on some of the WISP distributors around in your area see if you can get the dimentions of your routerboard with the cards injected in and make sure you get one that can hold that size. -Jordan
