I am looking for a solution to work wireless up to 90m Outdoor/Indoor.
I am interested in GrooveA 52 AC (including the omni 6/8dBi antenna) or Omnitik 5 AC POE. What is your suggestion? Do you have some experience with the models ?
Thank you very much for any help
Remember to order device with ROS Level at least 4. Level 3 does not let you configure device as AP.
Omnitik has two antennas which let you to broadcast 2.4GHz an 5GHz at same time, Groove lets choose one freq at the moment so Omniktik is more flexible.
Omnitik 5 ac allows only 5g band in two polarisations. Therefore it is better than groove which has only one chain. I would vote for omnitik if the option to switch to 2g band is not important. Be sure you put good antennas for clients or ensure there will be no foreign interference in the area of your interest.
My error … I have to agree.
Double frequency gives much, much better coverage so the solution should be for 2.4 and 5 GHz … what if clinet’s device is 2.4GHz capable only?
Can RBMetalG-52SHPacn 2.4/5GHz do 2.4 + 5Ghz simultaneously ?
Can it handle it same time without switching?
What equipment can broadcast 2.4Ghz and 5Ghz at the same time and 360degrees?
