info CCR1072-1G-8S+
Hi Normis,
Thanks for confirming that. Do you know if the CCR1036 does support ECC ram (if we had to swop the modules out).
Also, I understand the purpose of ECC ram in a server environment, but does ECC ram matter in a network router like the CCR’s?
Is there a risk of a CCR1036 catching a wobbly because of a bit-flip because it is not using ECC, or isn’t this something we should be concerned about?
-Dave
The device itself also must be made to support ECC, so just using ECC modules will not improve anything (except maybe that ECC modules will be higher quality in general).
So would you still recommend the CCR1036’s in a data center environment doing bgp/ospf/etc, even though it does not use ECC ram?
Out of curiosity, have you moved on with CCR1072?
Just an FYI
The CCR1036 does NOT support ECC ram :frowning: I have tested it
Yes we have, and they working like a boss.
