Info on ethernet over L3 (IP) bridging
can the native EoIP support multiple tunnel instances on a single router with a single IP?
Are the tunnels bridgeable with VLAN physical interfaces also on the router?
For an hub and spoke topology I imagine that each spoke must be configured each one with a tunnel.
Does mikrotik plan to support the standard VXLAN?
are the lite router reliable (I mean also the power supply) for 24/24h operation? thanks
thanks for any info
Yes you can do multiple EoIP tunnels in the same router with the same local IP Address, you just specify the tunnel ID for each tunnel.
thank you.
A pity the lack of VXLAN support… it would be nice for better interoperation…
