Hi there,
this is my first mikrotik device and I’m not able to get it running.
I followed the guide from pcunite and expanded it only to use more interfaces and IP-Ranges
But I’m not able to access the internet or the network between my isp router and router-os.
This is my setup:
ISP Router ↔ internal Network ← mikro tik (CRS326-24G-2S+)<-> Laptop
this is my configuration:
# jan/02/1970 00:25:00 by RouterOS 6.49
# software id = MWC8-F2JW
# model = CRS326-24G-2S+
add fast-forward=no name=bridge1 vlan-filtering=yes
/interface vlan
add interface=bridge1 name=V_Gast_99 vlan-id=99
add interface=bridge1 name=V_Haupt_10 vlan-id=10
add interface=bridge1 name=V_MGMT_69 vlan-id=69
add name=WAN
add name=VLAN
add name=BASE
add name=pool_V_Haupt_10 ranges=10.81.10.50-10.81.10.250
add name=pool_V_MGMT_69 ranges=10.81.69.50-10.81.69.250
add name=pool_V_Gast_99 ranges=192.168.1.50-192.168.1.250
add address-pool=pool_V_Haupt_10 disabled=no interface=V_Haupt_10 name=\
dhcp_V_Haupt_10
add address-pool=pool_V_MGMT_69 disabled=no interface=V_MGMT_69 name=\
dhcp_V_MGMT_69
add address-pool=pool_V_Gast_99 disabled=no interface=V_Gast_99 name=\
dhcp_V_Gast_99
add bridge=bridge1 interface=ether3 pvid=10
add bridge=bridge1 interface=ether4 pvid=10
add bridge=bridge1 interface=ether5 pvid=10
add bridge=bridge1 interface=ether6 pvid=10
add bridge=bridge1 interface=ether7 pvid=10
add bridge=bridge1 interface=ether8 pvid=10
add bridge=bridge1 interface=ether9 pvid=99
add bridge=bridge1 interface=ether10 pvid=99
add bridge=bridge1 interface=ether11 pvid=99
add bridge=bridge1 interface=ether12 pvid=99
add bridge=bridge1 interface=ether13 pvid=99
add bridge=bridge1 interface=ether15 pvid=99
add bridge=bridge1 interface=ether16 pvid=99
add bridge=bridge1 interface=ether17 pvid=69
add bridge=bridge1 interface=ether18 pvid=69
add bridge=bridge1 interface=ether19 pvid=69
add bridge=bridge1 interface=ether20 pvid=69
/interface bridge vlan
add bridge=bridge1 tagged=bridge1,ether2 untagged=\
ether3,ether4,ether5,ether6,ether7,ether8 vlan-ids=10
ether17,ether18,ether19,ether20 vlan-ids=69
ether9,ether10,ether11,ether12,ether13,ether15,ether16 vlan-ids=99
/interface ethernet switch rule
add dst-address=192.168.189.0/24 new-dst-ports="" ports=\
ether2,ether3,ether4,ether5,ether6,ether7,ether8 src-address=\
10.81.10.0/24 switch=switch1
ether9,ether10,ether11,ether12,ether13,ether15,ether16 src-address=\
192.168.1.0/24 switch=switch1
add interface=ether1 list=WAN
add interface=V_Haupt_10 list=VLAN
add interface=V_MGMT_69 list=VLAN
add interface=V_Gast_99 list=VLAN
add interface=V_MGMT_69 list=BASE
add address=192.168.189.2/24 interface=ether1 network=192.168.189.0
add address=10.81.10.1/24 interface=V_Haupt_10 network=10.81.10.0
add address=192.168.1.1/24 interface=V_Gast_99 network=192.168.1.0
add address=10.81.69.1/24 interface=V_MGMT_69 network=10.81.69.0
add address=10.81.10.0/24 dns-server=192.168.189.1 gateway=10.81.10.1
add address=10.81.69.0/24 dns-server=192.168.189.1 gateway=10.81.69.1
add address=192.168.1.0/24 dns-server=192.168.189.1 gateway=192.168.1.1
add action=accept chain=input comment="Allow Estab & Related" connection-state=established,related
add action=accept chain=input comment="Allow VLAN" in-interface-list=VLAN
add action=accept chain=input comment="Allow Base_Vlan Full Access" in-interface-list=BASE
add action=drop chain=input comment=Drop
add action=accept chain=forward comment="Allow Estab & Related" connection-state=established,related
add action=accept chain=forward comment="VLAN Internet Access only" connection-state=new in-interface-list=VLAN out-interface-list=WAN
add action=drop chain=forward comment=Drop
add action=masquerade chain=srcnat comment="Default masquerade" out-interface-list=WAN
add distance=1 gateway=192.168.189.1
/system routerboard settings
set boot-os=router-os
I can ping the router ip, but everything beyond the mikrotik is blocked and I don’t know why.
