Innbox bridge pass through
Hallo
Because my ISPs inbox modem problems i bought my own router (RB4011iGS).. While my grandparents still use house phones i hade to use ISP router to convert IP phone to normal (RJ11). i vas using VLAN 3998.. Now i noticed that they have change something and the vlan is not working anymore..
After some try and error we managed to get phone working again so that the Inbox router is connected via SFP (optic) to internet and is set as pass through to ports (port 1) and then to my mikrotik router to SFP.
The inbox does not set session but my mikrotik does via PPPOE.
This sort of works but i have noticed that few times a day the connection drops and i se in the logs “connection terminated” and in quick setup “failed to autethificate ourself to peer”.
I i put mikrotik infront of inbox i wont get such erorrs.
I was thinking about setting up bridge in mikrotik from SFP to Port3 that bypasses every NAT, firewall etc. and just bridges this 2 ports just for inbox without any conditions just freely open. and than to connect Inboxes WAN to that port3 on mikrotik.
I tried some setups but did not work. Please for your suggestions and help.
