the purpose here is to improve the read/write to a QNAP NAS that was recently installed. It is on VLAN 24, users are coming from either wired[VLAN 20] or wireless[VLAN10] with the respective ip pools set as 192.168.<>.0
The current problem:
Traffic to our mail server is extremely slow, quite often timing out on simple things such as ssh or even telnet to snmp port[465] or port[25].
Innter-Vlan traffic between VLAN 20/10 and VLAN 24 is extremely slow
rsync -av 100mb-dummy.test /mnt/test/
sending incremental file list
100mb-dummy.test
sent 104,883,294 bytes received 35 bytes 3,555,367.08 bytes/sec
total size is 104,857,600 speedup is 1.00
this is from a wired gig connection:
ifconfig enp0s25
enp0s25: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.20.196 netmask 255.255.255.0 broadcast 192.168.20.255
inet6 fe80::56ee:75ff:fe51:7278 prefixlen 64 scopeid 0x20<link>
ether 54:ee:75:51:72:78 txqueuelen 1000 (Ethernet)
RX packets 2401386 bytes 398152298 (379.7 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 2393253 bytes 911204394 (868.9 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 20 memory 0xf4200000-f4220000
If it helps at all I did grab a packet capture of the transfer from my local machine:
cpdump -nes0 -i enp0s25 ether host 00:08:9b:ed:32:20
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on enp0s25, link-type EN10MB (Ethernet), capture size 262144 bytes
09:36:19.335393 00:08:9b:ed:32:20 > 01:00:5e:7f:ff:fa, ethertype IPv4 (0x0800), length 458: 192.168.24.4.46117 > 239.255.255.250.ssdp: UDP, length 416
09:36:19.335435 00:08:9b:ed:32:20 > 01:00:5e:7f:ff:fa, ethertype IPv4 (0x0800), length 462: 192.168.24.4.46117 > 239.255.255.250.ssdp: UDP, length 420
09:36:19.335442 00:08:9b:ed:32:20 > 01:00:5e:7f:ff:fa, ethertype IPv4 (0x0800), length 494: 192.168.24.4.46117 > 239.255.255.250.ssdp: UDP, length 452
09:36:19.335446 00:08:9b:ed:32:20 > 01:00:5e:7f:ff:fa, ethertype IPv4 (0x0800), length 524: 192.168.24.4.33860 > 239.255.255.250.ssdp: UDP, length 482
09:36:19.335449 00:08:9b:ed:32:20 > 01:00:5e:7f:ff:fa, ethertype IPv4 (0x0800), length 522: 192.168.24.4.55217 > 239.255.255.250.ssdp: UDP, length 480
09:36:19.435522 00:08:9b:ed:32:20 > 01:00:5e:7f:ff:fa, ethertype IPv4 (0x0800), length 458: 192.168.24.4.44762 > 239.255.255.250.ssdp: UDP, length 416
09:36:19.435550 00:08:9b:ed:32:20 > 01:00:5e:7f:ff:fa, ethertype IPv4 (0x0800), length 462: 192.168.24.4.44762 > 239.255.255.250.ssdp: UDP, length 420
09:36:19.435558 00:08:9b:ed:32:20 > 01:00:5e:7f:ff:fa, ethertype IPv4 (0x0800), length 494: 192.168.24.4.44762 > 239.255.255.250.ssdp: UDP, length 452
09:36:19.435564 00:08:9b:ed:32:20 > 01:00:5e:7f:ff:fa, ethertype IPv4 (0x0800), length 524: 192.168.24.4.33476 > 239.255.255.250.ssdp: UDP, length 482
09:36:19.435570 00:08:9b:ed:32:20 > 01:00:5e:7f:ff:fa, ethertype IPv4 (0x0800), length 522: 192.168.24.4.48130 > 239.255.255.250.ssdp: UDP, length 480
^C
10 packets captured
10 packets received by filter
0 packets dropped by kernel
And lastly the configuration on the device, a CCR-1009 8 Port
I did try to paste the config here, but with all the layer 7 stuff I think I exceeded the size limit... so it's here
https://paste.fedoraproject.org/262486/11989221/
