input buffer overflow
Good Day.
I downloaded urlfilter file from non-working squid server and modified it so that it can just be copied and pasted inside mikrotik terminal.
It is a very big file (about 84000 urls) and the contents will be added to /ip proxy access
I don’t know how much entires “/ip proxy access” can take but around about 1800 then the terminal shows “input buffer overflow” and no more entries is created.
Any ideas?
You are not wrote:
Routerboard?
RouterOS?
Have you already contacted support@mikritik.com?
Hint: Restore the squid server.
It is routerboard RB2011UiAS and routeros 6.11
Did not contact support yet.
70% chance that i will restore squidserver.
Thank you
