input chain doesn work
hey guys need your help i have my internal nano station ip and it works perfect if i disable the default rules but the problem is if i enable cant redirect the traffic to nano ip heres my config
add action=dst-nat chain=dstnat comment=“station side nano” disabled=no dst-address=
xxx.xx.xxx.201 dst-port=12345 protocol=tcp to-addresses=10.11.0.30 to-ports=12345
in input chain
add action=accept chain=input comment=“nano allow” disabled=no protocol=tcp src-port=12345
in default drop rules is place in the bottom
add action=drop chain=forward comment=“” disabled=no out-interface=Ether1-WAN
how can i pass the traffic even the default drop rules is enable :slight_smile:
thanks
It doesnt go in the input chain, it is forwarding the traffic, so it goes in the forward chain. :wink:
thanks for response road but im accessing from outside
http://wiki.mikrotik.com/wiki/Manual:Packet_Flow
Destination NAT happens in prerouting. After that the packet’s destination address has been rewritten and it goes into the forward chain.
Change
add action=accept chain=input comment="nano allow" disabled=no protocol=tcp src-port=12345
to
add action=accept chain=forward comment="nano allow" disabled=no protocol=tcp src-port=12345
and make sure to put it above the deny all at the end.
fewi and road it works i really do appreciate ur help
regards
