baumie
September 11, 2010, 5:09am
1
Hi
I’ve got the following script to write the usage of our clients on the usermanager to a file but the output is one long string. I would like to insert a crlf after each client so that I can import it into exel. I tried /r/n but that does’nt work If anyone can give me a pointer on how to do this
:local downloadlused
:local uploadused
:local client
:local newtext
:local oldtext
/file set usage.txt contents=“”
/tool user-manager user
:foreach i in=[/tool user-manager user find subscriber=admin] do={
:set client [get $i name]
:set uploadused [get $i upload-used]
:set uploadused [:tostr $uploadused]
:set downloadlused [get $i download-used]
:set downloadlused [:tostr $downloadlused]
:set oldtext [/file get [/file find name=usage.txt] contents]
:set newtext ($oldtext . " " . $client . “,” . $uploadused . “,” . $downloadlused)
/file set usage.txt contents=$newtext
Thanks guys
The escape code for crlf is “\n”. Like this:
:set newtext ($oldtext . "\n" . $client . "," . $uploadused . "," . $downloadlused)
baumie
September 11, 2010, 1:13pm
3
It produces an output like this.
/nuser1,432144,545422/nuser2,8926069,80082044/nuser3,520311629,3529277308/nuser4,412520988,1554555323/nuser5,33844981,127074590/nuser6,1539238757,4064530441/nuser7,73536214,232673237
I need it to be like this
user1,432144,545422
thanks
fewi
September 11, 2010, 1:20pm
4
Looks like you’re using /n rather than \n.
baumie
September 11, 2010, 1:35pm
5
Wow thanks Fewi you’re the best
Technically:
CR = \r
LF = \n
CRLF = \r\n
Windows formats documents using CRLF, whereas unix/linux mostly only use LF.
Mikrotik console also uses CRLF to format output.
Ex.
:put “test1\ntest2”
test1
test2
:put “test1\rtest2”
test2
:put “test1\r\ntest2”
test1
test2
Hope this helps.
