Inserting new devices images into the Dude
I’ve the dude 7.16.1 and tried uploading images to the “/dude/files/default/images” but won’t take as it says “read only”.
Is there a way to add images to new devices created?
Thanks,
Pipa
Try to define an address like:
“/dude/files/images”
“/dude/files/default” is read only folder.
AFAIK, it like MIBs… you put it into the top-level “files” under the dude directory and it will be moved automatically.
And you can pick the new graphic on the device type to use it.
