I was looking through the HCL, and the Ralink RT2500 series isn’t supported by the routerOS, but does have linux drivers - is there a way to get 3rd party drivers working in the RouterOS?
Received the answer via documentation:
“Users cannot add their own device drivers, only drivers included in the Mikrotik RouterOS software packages can be used. If you need a support for a device, which hasn’t a driver yet, you are welcome to suggest it at suggestion page on our web site.”
send the information to support@mikrotik.com
Supout with the card installed also helps..
