Install a mikrotik web proxy
Good, I want you to please tell me the name of a free proxy web, to confirm it in a mikrotik to inform my clients when their service is disconnected due to lack of payment, thanks
Do you have a MikroTik as your gateway router? You can use the (free) proxy facility right in that router to do this. You will, however, need some website where you can store the message to the customer (it can be on your LAN if you have a server running 24/7).
Here is the configuration I used to present “out of service” messages to clients who had not paid their bills, and clients whose service was (mutually agreed) shut off for a season. I would just put their device names or addresses in the firewall address lists “arrears” or “standby” and all their traffic would be routed to an error screen on the server.
/ip firewall filter print
105    ;;; Process arrears...
      chain=forward action=jump jump-target=blocktraffic src-address-list=arrears
106    ;;; ...or standby
      chain=forward action=jump jump-target=blocktraffic src-address-list=standby
136    ;;;   Allow any DNS, NTP
      chain=blocktraffic action=return protocol=udp dst-port=53,123
137    ;;;   ...or (proxy redirected) HTTP
      chain=blocktraffic action=return protocol=tcp dst-port=80,443
138    ;;;   Don't log on EVERY packet
      chain=blocktraffic action=reject reject-with=icmp-network-unreachable src-address-list=throttle-notice
139    ;;;   Log arrears...
      chain=blocktraffic action=log src-address-list=arrears log-prefix="ARREARS"
140    ;;;   ...or standby
      chain=blocktraffic action=log src-address-list=standby log-prefix="STANDBY"
141    ;;;   No more logs about this user for 10 min
      chain=blocktraffic action=add-src-to-address-list address-list=throttle-notice address-list-timeout=10m
142    ;;;   Block all other subscriber traffic
/ip firewall nat print
11    ;;; Arrears notice
      chain=dstnat action=redirect to-ports=8081 protocol=tcp src-address-list=arrears dst-port=80,443
12    ;;; Standby notice
      chain=dstnat action=redirect to-ports=8082 protocol=tcp src-address-list=standby dst-port=80,443
/ip proxy access export
add dst-address=999.999.999.999 dst-host=somewhere.somewhere.xyz
add action=deny comment="\"Pay bill\" notice" dst-port=80,443 local-port=8081 \
            redirect-to=somewhere.somewhere.xyz/arrears.html
add action=deny comment="Seasonal standby notice" dst-port=80,443 local-port=8082 \
            redirect-to=somewhere.somewhere.xyz/non-ws/standby.html
add action=deny comment="Secure the proxy"
/ip proxy print
                 enabled: yes
             src-address: ::
                    port: 8081,8082
               anonymous: no
            parent-proxy: 0.0.0.0
       parent-proxy-port: 0
     cache-administrator: you@wherever
          max-cache-size: none
   max-cache-object-size: 2048KiB
           cache-on-disk: no
  max-client-connections: 100
  max-server-connections: 100
          max-fresh-time: 1m
   serialize-connections: no
       always-from-cache: no
          cache-hit-dscp: 4
              cache-path: web-proxy1
Thank you for your code
