install a paskage via consile
Hello.
The https://help.mikrotik.com/docs/display/ROS/Packages contains examples for manipulate of packages, but example of installation is missing. For example I have wireless-7.13.4-arm.npk on flash:
[admin@MikroTik] > file/print
Columns: NAME, TYPE, SIZE, CREATION-TIME
#  NAME                     TYPE       SIZE       CREATION-TIME
0  wireless-7.13.4-arm.npk  package    2704.1KiB  2024-02-26 01:15:52
1  flash                    disk                  1970-01-01 04:00:17
2  flash/skins              directory             1970-01-01 04:00:18
3  flash/pub                directory             1970-01-02 04:09:29
How can I install it?
After you place optional package to the root of router’s storage, it’ll get installed (if it’s correct for the device) automatically when you reboot device.
Thanks. It’s similar to updating the base package, but I didn’t guess. Is it probably worth mentioning? :slight_smile:
it is clearly explained in beginning of the manual you linked
