i try install mikrotik(6.19) x86 in Mini-ITX
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=728#spec
but it show “no hard disk drive fond” and i try to install with USB Flash Drive & Harddisk(WD RED1TB) and SSD it not work.
i swap install device usb & harddisk to try in desktop computer ok it work
please help me. thank
update:
- i has change SATA config ACHI to IDE. it not work
- ok i instaill ubuntu in this mainboard it work! but mikrotik it not work
Look at this list what hardware is supported by Mikrotik
http://wiki.mikrotik.com/wiki/Supported_Hardware
make sure you set the SATA mode to IDE.
The installer should detect the HDD after that.
Haven’t installed x86 in a long time, but what I did a long time ago was install on some pc and then move the hard disk to another.
thank all guy i’ll try again and again
MT seems to be not interested in x86 arch. The supported H/W list needs updates. Found problems with newer chipsets. Still in darkness about support for newer chips like e350, x99 etc
