install packages
Hi
I need install the RSTP package but I couldn’t. I tried droping the file in ‘files’ menu in the winbox, I upgraded OS version doing that and it worked, but not now. I also tried droping the file in the packages menu but it says ‘Could not change the key - invalid key’-
Can you help me?
regards
you must drop it in the files window. is the package the same version and type as the rest of them?
It’s the one in the download page, I have to down the version of my RouterOS? I can’t have this package with version 3 in RouterOS??
I need v3 RouterOS and the rstp package, how can I do?
thanks you!
If you have installed v3.0 then rstp package is integrated into system package.
