Install RouterOS in existing network
Hi folks,
I do have a demo network 192.168.10.0/24. This network is used for demonstrations of different products. My goal is to integrate RouterOS in 192.168.10.0/24 and access it via the web interface where I can demonstrate MikroTik features. I want to connect the Mikrotik router to the existing switch, and eventually add one host to MikroTik LAN to have some traffic going on.
I am a bit confused about how to do it. The MikroTik router has a default IP 192.168.88.1/24, when I change it to 192.168.10.x - it doesn’t work. Do I need to connect MikroTik WAN to the existing switch or I need to connect MikroTik LAN to the existing switch. How to configure it?
Thank you in advance.
Best
YAz
I would:
  • Reset the device, no default configuration
  • Create a bridge
  • Add all interfaces to the bridge
  • Add DHCP client to the bridge
After this, you can browse to the IP assigned to the RB.
What would you like to demonstrate?
