I’m trying to install the x86 server in a HP ML310e V2 Gen8, but when it finishes installing it reboots, it requests the default login before you even enter the login it appears the message that the license has expired and halt the server.
ok, I buy the license, as I put the license if he leaves or I enter the system. I installing from a flash drive (USB drive) mounted with a netinstall.
Thank you, best regards,
