installation packages
If a PC or routerboard is installed using combined package (routeros-x86-2.9.43.npk, routeros-rb500-2.9.43.npk) can I convert them so they will be using separate packages? If yes, than how to do that?
you still are able to remove the packages individually. it’s the same as using separate packages
