Hi all. I need help on the following. I have a routerboard 133/133C loaded with some sort of openware software. I would like to install the mikrotik routeros software, and have done the following:
I connected a serial cable and an ethernet cable. Using hyperterminal, I can get into the bios of the router. I set it to boot from ethernet. I then used the netinstall program. The problem is that the netinstall program can’t see the router. On the hyperterminal screen I can see the router trying to find a dhcp server?? Can anyone help please as this has been bothering me for the past 2 weeks.
Quote: “Watch the serial console as the RouterBoard reboots, it will indicate that the RouterBoard is attempting to boot to the NetInstall program. The NetInstall program will give the RouterBoard the IP address you entered at Step 4 (above), and the RouterBoard will be ready for software installation. Now you should see the MAC Address of the RouterBoard appear in the Routers/Drives list of the NetInstall program.”
It is at this point mentioned above that the Net install program does not see the router. Any suggestions??
Did you connect the router to the windows PC directly with the correct type of ethernet cable? make sure to disable any other interfaces in your windows pc, and turn off the firewall
Last night I downloaded a tftp server, and tried to upload the .npk file to the router. The router received an dhcp address, but still would not boot. Any Help would be much appreciated. Thanx
