I am setting up a test environment so that I can learn how to setup a hotspot. I have downloaded the latest routerOS from the website and installed in on an old Sony Viao laptop I have. I am using 2 pcmcia cards on to connect to the LAN and the other is a wireless card.
The problem I have is that I cannot see either card when I use the /interface print command. One of the cards is a prism and the other is a dlink-DFE 650. THe current irq’s are below
Ricoh Co Ltd RL5c478 =9
usb-uhci =9
I am not sure if the irq’s are the problem but if they are how do I change them?
I have a stupid suggestion, but have you tried to remove one card, swap the PCMCIA slots in which they are inserted?
I also had a problem regarding empty output in /interface print, but it is interesting that i never experienced this on routerboard, only on x86 version and regular PC. A lot depends on the chipset type in your laptop. I hope is is Intel based.
I have tired what you suggested but it’s made no difference. The laptop does have an intel chipset … I have also download the x86 npk from the site but I can’t upgrade from CD ?? Oh well any other ideas on how to get this working.
I have 19 hrs to run on this version I have. If I can get it working I will buy a licence. When I start to routerOS it gives me the message the router has no software key. It then shiws me the current installation software ID and then press enter to continue. Does this mean I can only use the routerOS locally until I buy a licence ?
OK I am just buying a Dlink DWL 650G card which is in the list as compatible. I am struggling to find an Ethernet pcmcia card though, can you suggest one please ?
Please can someone tell me what card I can buy that is compatible with the routerOS … I have looked through the supported device list and really can’t seem to workout what card to buy. This for a test environment as I am using an old PII laptop.
