Installing Calea
it says:
CALEA features included in RouterOS
Multiple subject/multiple destination packet interception and streaming in following formats:
  • Call Content Connection (CCC) Interface according to PKT-SP-ES-DCI-I01-060914 (PacketCable 2.0 PacketCable Electronic Surveillance Delivery Function to Collection Function Interface Specification)
  • Call Content Connection (CCC) Interface according to ANSI/SCTE 24-13 2006 (IPCalblecom Electronic Surveillance Standard) that is approved method for Communication Content delivery to LEA according to ATIS-1000013.2007 (Lawfully Authorized Electronic Surveillance For Internet Access and Services)
  • TZSP format - for reception with ‘Ethereal’, tcpdump, trafr (sniffer stream reader for linux) - http://www.mikrotik.com/download.html
I couldn’t find first two CCC, I found Trafr sniffer reader for linux but I couldn’t find anywhere to install it.
How can I download and install it?
I installed v3.8, and Installed Calea from All_packages, I donno If I am right or not. When I said system packages print:
NAME VERSIO
0 calea 3.8
1 routerboard 3.8
2 X ipv6 3.8
3 system 3.8
4 ntp 3.8
5 routeros-powerpc 3.8
6 mpls 3.8
7 wireless 3.8
8 dude 3.8
9 hotspot 3.8
10 routing 3.8
11 security 3.8
12 ppp 3.8
13 dhcp 3.8
14 advanced-tools 3.8
it shows like this but I couldn’t find any menu in Winbox.
look in command line - calea have no GUI as far as i know
what’s the command of that?
it’s /tool calea
It has been a bit since I have played with the CALEA system ( a vew releases) I have ben like the “decapitated chicken”… but CALEA is implimented in two parts.
  1. The interception point or “probe”..
    The settings are available via the console / terminal / CLI only under IP firewall.
    Here you define the “triggers” and where to send the data stream or other information (the “server”)
  2. The “Server” or collection point.
    These settings are under Tools/CALEA.
    The “server” collects the data sent to it via UDP and places it in files on its internal storage device.
Search the WIKI for " CALEA" there is a writeup on it by Butch Evans along with a sample config.
With the WISPA CALEA standards being released at the MUM and ISPCon. there will probably be an update to this document available after the MUM. ( A great reason to attend the MUM)..
I would also think there will be updates to the CALEA package from MikroTik about the same time..
