Installing Hotspot with RB433 and Omni antenna
Hello great people,
I’m trying to configure a hotspot with RB433 radio and after all my lessons and configuration, i can see the splash page when i browse the ip but pages are not redirecting to the login page.
Also do i need to setup bridge to create an AP.
Thanks in advance.
Well, first of i will put on the ether, the dhcp clientor a static ip to get the router to the internet, make s Ping to a external site so you are sure the router its online.
Once its online you should put an ip address on the wlan interface. Example: 172.16.1.254/24
Then go to ip-hotspot and run the wizard on the wlab interface and be sure to have mascarade network checked.
And i thing thst will work.
