Installing MikroTik into Embedded Disk Card
Dear all,
Does anybody here try installing MikroTik into a Embedded Disk Card?
The Embedded Disk Card info can be found at the URL below: -
http://www.anewtech.net/products_subsub_list.php?parentProduct=115
:smiley:
Yeah - sure. No problem, just install the same way as to a regular hard disk. We have lots of systems running on IDE-DOMs (the same thing), and you can even purchase those directly from MikroTik with the software already installed…
Best regards,
Christian Meis
Thanks for the info… :smiley:
