I have this mini pcie card out of a senao nl-3054cb3 plus ap. I would like to use it in the rb532. This is supposed to be an atheros based card. When installing the card, do I need to add drivers from some other package, or should it be plug and play? I have never installed a wireless card in the routerboard products and haven’t found a good source of instruction. I’m using router os v. 3.22 on the router.
The 532 has mini PCI not mini PCIe ports…
The card wont fit…
Look at a rb52 or similar card…
Sorry, used the wrong term. The card I have does fit in the slot.
in that case, plug in the card, turn on the device, and then check the “/interface wireless” menu in RouterOS. it will work automatically. if it doesn’t - check if you have the wireless package installed and enabled in “/system packages”
