Hi all
I Have Sever HP Proliant ML 150g6
I Install Mikrotik 3.30 but I have problems
(Looking for Hardisk …
Found Harddrive as SATA 1
FATAL: Erorr no CD- ROM Found
Press Enter to reboot
What is the problem??
Thanx
Hi all
Thanx
Is the CD drive PATA or SATA. If it is SATA use PATA to install. Also use the latest version.
Thannnxxx very mach
Sokran
Hi
Server not contain a PATA Socket , I used PATA CD-ROM via USB Converter but the problem not solved
If your server has a NIC that supports PXE boot, then you might just try netinstall. http://wiki.mikrotik.com/wiki/Manual:Netinstall
If you don’t have a PXE NIC, you can stick the HD into another machine and get it installed, then swap it back.
