Hello MikroTik Community,
I am trying to run a V2Ray container (or any similar proxy service) on my hAP ax S device, with all files stored on a USB drive (/usb1) to avoid using internal storage.
I have attempted using the "teddysun/v2ray:latest" image, but it exited immediately with "Illegal instruction". I suspect this is due to CPU architecture compatibility (ARM32 vs ARM64).
Here is my device information:
- RouterOS version: 7.22beta5 (testing)
- Board name: hAP ax S
- CPU: ARM, 2 cores
- Total memory: 512 MB
- Free memory: 410 MB
- Total storage: 128 MB
- Free storage: 76 MB
My questions:
- Is it feasible to run V2Ray (or Xray) on hAP ax S using containers with all files on USB?
- Are there specific ARM32-compatible images recommended for this device?
- Are there best practices for CPU/RAM-limited MikroTik models when running proxy containers?
Any advice or guidance would be highly appreciated. Thank you!
Those aren’t the only two choices. Read this, then note that the images you refer to stop at linux/arm/v6.
If you don’t like the advice at the first link — port it yourself — I advise that you either get a more capable device or limit your usage to what comes built-in, like Wireguard.
Thanks for the clarification.
You are right — ARM32 vs ARM64 is an oversimplification, and the Docker images I tested indeed only go up to linux/arm/v6, which explains the illegal instruction issue on this platform.
At this point, my main goal was to understand whether anyone has successfully run any userland proxy (V2Ray/Xray or similar) on hAP ax S specifically, or if the practical limitations of RouterOS containers on this architecture make it unrealistic without self-porting.
Porting it myself is technically possible, but given the device constraints (ARM architecture, limited storage, RouterOS container environment), I wanted to confirm first whether this is a known dead end on this model.
If the consensus is that hAP ax S is not a good candidate for such workloads, I agree that sticking to built-in features like WireGuard or moving this functionality to a more capable device is the sensible approach.
Appreciate the input.
