i hope you can help. I am very new to Mikrotic Routers.
I want to change my single router for a HAP AC + WAP AC.
I want to control the networks and users via CAPSMAN on the HAP AC.
I have managed to get CAPSMAN running and the WAP AC integrated.
But i struggle to get the HAP AC integrated WLAN running with CAPSMAN.
When i add them to CAPSMAN, they grey out and say “configured by CAPSMAN” but they dont activate and dont show up in the CAPSMAN interfaces.
I have searched and tried a lot with no success.
I have also reset the HAP AC and tried to only get the local interfaces running with CAPSMAN with no success.
Maybe its just something small.
Thanks for the help
It’s actually quite unbelievable that no one in this forum was able to move a finger to help, now that I’ve just happened to stumble upon the problem and managed to fix it a few hours ago. I’m sure this would’ve been dead easy for any hardcore routerOS person on here.
Go to IP > Firewall and disable the default rule commented as “drop all not coming from LAN”. That should immediately add the local wlan interface(s) to CAPsMAN. Not sure why this comes like this by default, as obviously it prevents you from CAP-ing the local wifi interfaces on that same CAPsMAN device.
This needs to be disabled because obviously traffic from the local wlan interfaces is not coming from the LAN interface…
Would’ve preferred you actually helped when I needed, rather than arriving late to the party and pooping all over it.
Turns out you’re wrong, and I’m only correcting you for the sake of future reference and people actually not becoming misinformed because of your reply on here. You do need to open up :5246 and :5247 for discovery, even if you are only using Layer 2. http://forum.mikrotik.com/t/capsman-work-only-layer2-solved/75629/1
Also, hope you don’t have to actually use the search on this forum to find something you quite desperately need, otherwise you’d realise the huge foot in your mouth you’d have to remove.
I tried to connect the integrated wlan to capsman with a RB2011, a CRS109 and a map Lite. It only worked with the map Lite which I just did for testing purpose. I also went through a lot of tutorials and of course the advices from the forum here including firewall rules etc.
So finally I’m stuck and can not get any further because I lost every ideas what to check furthermore. It seems that the provisioning of the integrated caps is a problem…
