Greetings,
I have recently purchased a RB2011UiAS-RM and a RBcAP2n. I have the basics setup and everything is running smoothly. I purchased this combo since I wanted the radio in a more centralized location than where the RB2011 would be racked.
My questions is seemingly simple; can I somehow “integrate” the RBcAP2n into the RB2011 so that I can manage it in one place? Basically you would normally find the onboard WiFi card (if I had one) listed under Wireless. I have read up a bit on CAPsman but I am not sure that this is the best way since I only have one device. Are there any negatives to CAPsman? a better way to integrate the RBcAP2n?
Thoughts?
Thanks so much in advance for taking the time to reply.
