No, there is not a clean way to do that. At least, not that I know of. You could script both the RADIUS and Mikrotik, but the trade off would be service interruptions for the normal customers. You could create a Virtual AP that directed customers like that. Hope that helps
Actually… if you use the API… you could script the RADIUS to dynamically create access lists. That way you could move the customer off of one AP and onto to another AP (a VAP with the same SSID, maybe hidden) that was pointed in the direction you want them to go. It wouldn’t be 100% problem free, but that might be possible.
