integration wifi in the network mikrotik with router WIFI
Hello All
I have a Mikrotik installed on a desktop with two network cards
a card for the LAN and one for the WAN
I would also make the WIFI
so I have a DLINK WIFI router that I want to install in my network to the WLAN and make a
Authentication using the Mikrotik hostpot
Thanks for your prompt response
If you want to have a network which isn’t authenticated and and network that is then you will need either another ethernet adaptor or a managed switch and then setup vlans.
I want to do with authentication, I want to put the WiFi router’s WAN interface in the network
Local and allow the mac address of wan router wifi in the router Mikrotik
and after that will allow customers to connect wireless to authenticate using the account created in the Mikrotik
just disable dhcp in wireless router and plug wire in lan port of wireless router
The problem is that I have several customers behind the wireless router that must authenticate
in Mikrotik, Mikrotik knows just the mac address of the wan port of the wireless router
but do not know the mac of desktop behind the wireless router
that’s what I’m talking
and how to do as soon as a customers behind the wireless router has authenticated, while other
have access to the internet and I do not want this,
I would like all users behind the router have wireless authentication page
and even if a customers behind the router that connects to wifi other’ve always page
Authentication
Thanks for your help et sorry for my bad english
I’m assuming you’re using a Hotspot.
You can’t do what you’re trying to do. The Hotspot must be the first layer three hop.
Ok, thanks for your reply
