Intel 82571EB problem
Hello a have strange problem
in router installed two NICs
  1. Intel Server Adapter PRO/1000 PT (82572EI)
  2. Intel Dual Port Server Adapter PRO/1000 PT (82571EB)
(82572EI) – works perffect
(82571EB) – in low loads (pinging another host) works fine when i try to load NIC pings sudenly stops with timeouts and time to time on rear panel NIC LEDs Stops lights and after second lights up again . after load removed, remote host strarts to ping again
My CPU i5 4Cores MB Intel with P55 chipset
RouterOS 5beta6 and RouterOS 4.11
please help me
did you tried this?
/system hardware set multi-cpu=no
solved it’s my mainboard issue
replaced to new one and everything ok now
