Hi on one sight, I had alix, but changed it for intel atom board - intel dn2800mt. Because of very low energy consumption(15w) and passive cooling.
Before it, there was alix board(pci engines). TThe procesor of alix ran on 70%, in intel just max. 5%.
But the problem is big ping on both ethernet ports(one is integrated intel) and anothere is intel pro/1000 ct.
Both are working, but ping to other router(connected using 3m ethernet cable, is in average about 4ms(before it was max.1ms…).
I didnt tryed to turn off hyperthreading.
Here are some pictures… http://i50.tinypic.com/xm37r5.jpg http://i48.tinypic.com/2udw4k9.jpg http://i46.tinypic.com/eoy6r.jpg
What do you think? What can be wrong? Do you think, that downgrade could help?
5% CPU usage at what throughput? NAT+firewall+mangle+conn track?
I’m interested in this board myself as it is cheap and high performance. If I get it, I’m thinking of modifying the pcie x1 slot to accommodate pcie x4 RB44ge card to bypass potential NIC driver incompatibilities in ROS.
