Hi, i want to used on DN2800MT the following SFP card.
http://eu.startech.com/Networking-IO/Adapter-Cards/PCI-Express-Gigabit-Ethernet-Fiber-Open-SFP-PCIe-Network-Card-Adapter-NIC~PEX1000SFP
Are this card will be understand the ROS ?
What power supply do you use for DN2800MT
Some supply converter and PSU 48V.
I don’t have an answer for your question, but I should buy a card with Intel chipset instead. These are much better and better supported by RouterOS.
The DN2800MT can only deliver +/- 10 watt to the PCI-e slot, but that should be more than enough.
