Hello, I have a Intel PCI-Express 10/100/1000 with 82574L chip and it don’t work, I have seen the hardware supported and it isn’t supported by RouterOS but I have seen to much Intel interface are supported.
In the official web of Intel this driver is open source, Is it possible to do it work? and how?
82573L works fine %) did you try v3.28? if yes - then make supout.rif and send to support@mikrotik.com - maybe they can add support of this card in future versions
