Hello Everyone
I need some help please.
I got a microtik router and a Cisco Smalbusiness, I've configured three vlans
192.168.10.0/24 vlan10
192.168.20.0/24 vlan20
192.168.30.0/24 vlan30
with their respective gateways:
192.168.10.1/24
192.168.20.1/24
192.168.30.1/24
And I need vlan10 and 30 comunicate with vlan20
But for some reason I 'm not able to do it.
The internet is working, the dhcp for every vlan is working, PCs in the same Vlan can see each other but I can't enable the intervlan routing, I can't ping vlan 20 PC with vlan 30 PC, I've tried some tips or articles from the forums but i'm still stuck at this, I don't know what im doing wrong.
Help please.
Here is the router configuration:
apr/25/2019 22:10:18 by RouterOS 6.34.4
software id = V038-NV6J
add admin-mac=6C:3B:6B:8C:F3:9D auto-mac=no name=bridgeLocal
set [ find default-name=ether1 ] name="ether1 WAN"
set [ find default-name=ether2 ] name="ether2 LAN"
/interface vlan
add interface="ether2 LAN" name=ADMINISTRATIVO vlan-id=10
add interface="ether2 LAN" name=CLINICA vlan-id=20
add name=dhcp_pool1 ranges=192.168.10.100-192.168.10.200
add name=dhcp_pool2 ranges=192.168.20.100-192.168.20.200
add address-pool=dhcp_pool1 disabled=no interface=ADMINISTRATIVO name=dhcp1
add address-pool=dhcp_pool2 disabled=no interface=CLINICA name=dhcp2
add bridge=bridgeLocal interface=ether3
add bridge=bridgeLocal interface=ether4
add bridge=bridgeLocal interface=ether5
/interface wireless cap
set bridge=bridgeLocal discovery-interfaces="ether1 WAN" enabled=yes
interfaces=wlan1
add address=192.168.1.1/24 interface="ether2 LAN" network=192.168.1.0
add address=192.168.10.1/24 interface=ADMINISTRATIVO network=192.168.10.0
add address=192.168.20.1/24 interface=CLINICA network=192.168.20.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface="ether1 WAN"
add address=192.168.10.0/24 dns-server=8.8.8.8,200.107.10.105 gateway=
192.168.10.1
add address=192.168.20.0/24 dns-server=8.8.8.8,200.107.10.105 gateway=
192.168.20.1
set servers=8.8.8.8
add action=masquerade chain=srcnat out-interface="ether1 WAN"
add distance=1 gateway="ether1 WAN"
add distance=1 dst-address=192.168.0.0/22 gateway=192.168.1.1
/system clock
set time-zone-name=America/Guayaquil
/system leds
set 0 interface=wlan1
/system routerboard settings
set protected-routerboot=disabled
