Hello guys,
I’m having trouble reaching the devices on VLAN12 from a service PC that resides on VLAN11. I can reach the devices on all other VLANS from this PC (like unifi switches that are on VLAN10, ecc…).
I have rules in the firewall to block all access from VLAN13 (a guest reserved VLAN for external users) to other VLANs, but even if I disable these rules the problem is still there.
As you see I have used mangle to create a static route/rule because this customer has 2 internet routers (an optic fiber for normal internet access and a backup ADSL on which I have routed the VoIP traffic from the VLAN12 with said mangle, reserved for IP phones connected to a cloud pbx)
I hope I made myself clear. Here is my config
jun/20/2022 15:58:20 by RouterOS 6.47.8
software id = UDB2-X12K
model = 2011iL
serial number = 7DCF073A6FC2
add admin-mac=6C:3B:6B:D6:0F:52 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] mac-address=6C:3B:6B:D6:0F:51
set [ find default-name=ether2 ] mac-address=6C:3B:6B:D6:0F:52
set [ find default-name=ether3 ] disabled=yes mac-address=6C:3B:6B:D6:0F:53
set [ find default-name=ether4 ] disabled=yes mac-address=6C:3B:6B:D6:0F:54
set [ find default-name=ether5 ] mac-address=6C:3B:6B:D6:0F:55
set [ find default-name=ether6 ] disabled=yes mac-address=6C:3B:6B:D6:0F:56
set [ find default-name=ether7 ] disabled=yes mac-address=6C:3B:6B:D6:0F:57
set [ find default-name=ether8 ] disabled=yes mac-address=6C:3B:6B:D6:0F:58
set [ find default-name=ether9 ] mac-address=6C:3B:6B:D6:0F:59
set [ find default-name=ether10 ] disabled=yes mac-address=6C:3B:6B:D6:0F:5A
/interface vlan
add interface=ether5 name=VLAN10_MGMT vlan-id=10
add interface=ether5 name=VLAN11_Uffici vlan-id=11
add interface=ether5 name=VLAN12_Telefoni vlan-id=12
add interface=ether5 name=VLAN13_Guest vlan-id=13
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=default-dhcp ranges=192.168.88.100-192.168.88.200
add name=MGMT_pool ranges=192.168.10.50-192.168.10.250
add name=uffici_pool ranges=192.168.0.50-192.168.0.250
add name=TELEFONI_pool ranges=192.168.12.50-192.168.12.250
add name=GUEST_pool ranges=192.168.13.50-192.168.13.250
add name=OVPN_pool ranges=192.168.30.100-192.168.30.200
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add address-pool=MGMT_pool disabled=no interface=VLAN10_MGMT name=vlan10_dhcp
add address-pool=uffici_pool disabled=no interface=VLAN11_Uffici name=
vlan11_dhcp
add address-pool=TELEFONI_pool disabled=no interface=VLAN12_Telefoni name=
vlan12_dhcp
add address-pool=GUEST_pool disabled=no interface=VLAN13_Guest name=
vlan13_dhcp
/ppp profile
add local-address=192.168.10.1 name=ovpn_fidia remote-address=OVPN_pool
/queue simple
add max-limit=2M/10M name=Test_2 queue=ethernet-default/ethernet-default
target=10.10.13.0/24
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add interface=ether2 list=WAN
/interface ovpn-server server
set certificate=server cipher=blowfish128,aes128,aes192,aes256 enabled=yes
port=11940 require-client-certificate=yes
add address=192.168.88.1/24 comment=defconf interface=bridge network=
192.168.88.0
add address=192.168.0.1/24 interface=VLAN11_Uffici network=192.168.0.0
add address=192.168.10.1/24 interface=VLAN10_MGMT network=192.168.10.0
add address=192.168.12.1/24 interface=VLAN12_Telefoni network=192.168.12.0
add address=192.168.13.1/24 interface=VLAN13_Guest network=192.168.13.0
/ip dhcp-client
add comment=defconf default-route-distance=2 disabled=no interface=ether1
add disabled=no interface=ether2
/ip dhcp-server lease
add address=192.168.0.70 client-id=1:f4:2:70:aa:de:ae mac-address=
F4:02:70:AA:DE:AE server=vlan11_dhcp
add address=192.168.0.102 client-id=1:98:ee:cb:75:aa:44 mac-address=
98:EE:CB:75:AA:44 server=vlan11_dhcp
add address=192.168.0.0/24 comment=UFFICI dns-server=8.8.8.8,8.8.4.4 gateway=
192.168.0.1
add address=192.168.10.0/24 comment=MGMT dns-server=8.8.8.8,8.8.4.4 gateway=
192.168.10.1
add address=192.168.12.0/24 comment=TELEFONI dns-server=8.8.8.8,8.8.4.4
gateway=192.168.12.1
add address=192.168.13.0/24 comment=GUEST dns-server=8.8.8.8,8.8.4.4 gateway=
192.168.13.1
add address=192.168.30.0/24 gateway=192.168.30.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add action=accept chain=input comment=
“defconf: accept established,related,untracked” connection-state=
add action=drop chain=input comment=“defconf: drop invalid” connection-state=
invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
“defconf: accept to local loopback (for CAPsMAN)” dst-address=127.0.0.1
add action=accept chain=input comment=WinBox in-interface=VLAN11_Uffici
add action=accept chain=input comment=OVPN dst-port=11940 in-interface=ether2
protocol=tcp
add action=accept chain=input comment=WinBox_WAN dst-port=8291 in-interface=
ether2 protocol=tcp
add action=drop chain=forward in-interface=VLAN13_Guest out-interface=
VLAN11_Uffici
VLAN12_Telefoni
VLAN10_MGMT
add action=drop chain=input comment=“defconf: drop all not coming from LAN”
in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy”
ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy”
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
connection-state=established,related disabled=yes
“defconf: accept established,related, untracked” connection-state=
add action=drop chain=forward comment=“defconf: drop invalid”
connection-state=invalid
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
/ip firewall mangle
add action=mark-routing chain=prerouting in-interface=VLAN12_Telefoni
new-routing-mark=to_Fastweb passthrough=yes
add action=masquerade chain=srcnat comment=“defconf: masquerade”
add action=dst-nat chain=dstnat comment=“UltraVNC Ilaria” dst-port=6688
in-interface=ether2 protocol=tcp to-addresses=192.168.0.102 to-ports=6688
add distance=1 gateway=192.168.1.1 routing-mark=to_Fastweb
/ppp secret
add name=martina profile=ovpn_fidia service=ovpn
add name=nicola profile=ovpn_fidia service=ovpn
add name=andrea profile=ovpn_fidia service=ovpn
add name=kyle profile=ovpn_fidia service=ovpn
/system clock
set time-zone-name=Europe/Rome
/system identity
set name=FIDIA
/tool mac-server
/tool mac-server mac-winbox
