Hi
I have a hex router and need to create the following setup
2 vlans which traffic can route between and a dhcp server on one of the vlans
Setup needs to be
Ether 4
Vlan 10 -control
Dhcp server ip - 10.0.100.0/24
Ether 5
Vlan 20 - lighting
No dhcp - ip range : 10.101.10.0/24
Any idea the best way to do this??
anav
April 6, 2019, 12:02pm
2
Confusing as to why traffic going to a network switch from the router needs no dhcp setting but just a network. How will devices get IPs?? or are you setting them all statically.
This is pretty basic stuff but a good reference is the following…
You need a bridge
You need two DHCP subnets associated with vlans
One gives out DHCP IPs the other does not
Both vlans are associated with the bridge
Both ports attaching to the network switches would be trunk ports
The issue is I want to use too dumb switches and not need to set vlans up on the switch.
The switch side of the hex router can do vlans as well.
I want each vlan to be on a separate port and not tagged
anav
April 7, 2019, 6:58pm
4
In that case treat the the ports to the unmanaged switches as access ports.
add bridge=NameofyourBridge —> ingress-filtering=yes interface=ether4 allow only untagged and priority packets pvid=100
add bridge=NameofyourBridgfe —> ingress-filtering=yes interface=ether5 allow only untagged and priority packets pvid=101
/interface bridge vlan
add bridge=NameofyourBridge tagged=NameofyourBridge untagged=eth4 vlan-ids=100
add bridge=NameofyourBridge tagged=NameofyourBridge untagged=eth5 vlan-ids=101
Note if you actually had any trunk ports on the hex with those vlans on them they would be tagged
The hex router seems to lack the vlan section under bridge.
anav
April 8, 2019, 12:34am
6
Well, who is in charge here, you or the hex router LOL.
mkx
April 8, 2019, 5:12am
7
Which version of RouterOS?
Hi so i have updated the hex router and made a config but its not working correct.
Here is the config
add admin-mac=B8:69:F4:BF:6A:40 auto-mac=no comment=defconf name=bridge vlan-filtering=yes
/interface vlan
add interface=bridge name=Control vlan-id=20
add interface=bridge name=Lighting vlan-id=10
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=VLAN
add name=control-dhcp ranges=10.0.100.230-10.0.100.249
add name=Lighting-dhcp ranges=10.101.10.230-10.101.10.249
add address-pool=control-dhcp disabled=no interface=Control name=control
add address-pool=Lighting-dhcp disabled=no interface=Lighting name=lighting_dhcp
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface=ether4 pvid=20
add bridge=bridge comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface=ether5 pvid=10
add bridge=bridge comment=lighting tagged=bridge untagged=ether5 vlan-ids=10
add bridge=bridge comment=control tagged=bridge untagged=ether4 vlan-ids=20
add interface=Lighting list=VLAN
add interface=Control list=VLAN
add address=10.0.100.254/24 comment=defconf interface=Control network=10.0.100.0
add address=10.101.10.254/24 interface=Lighting network=10.101.10.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
add address=10.0.100.0/24 comment=defconf gateway=10.0.100.254
add address=10.101.10.0/24 gateway=10.101.10.254
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
add action=accept chain=input comment=“defconf: accept established,related,untracked” connection-state=established,related,untracked
add action=drop chain=input comment=“defconf: drop invalid” connection-state=invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=accept chain=forward comment=“defconf: accept in ipsec policy” ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy” ipsec-policy=out,ipsec
add action=accept chain=input comment=“Allow VLAN” in-interface-list=VLAN
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack” connection-state=established,related
add action=accept chain=forward comment=“defconf: accept established,related, untracked” connection-state=established,related,untracked
add action=accept chain=input comment=“Allow Estab & Related” connection-state=established,related
add action=drop chain=input comment=Drop
add action=accept chain=forward comment=“Allow Estab & Related” connection-state=established,related
add action=accept chain=forward comment=“VLAN inter-VLAN routing” connection-state=new in-interface-list=VLAN
add action=drop chain=forward comment=“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=drop chain=forward comment=Drop
add action=masquerade chain=srcnat comment=“defconf: masquerade” ipsec-policy=out,none out-interface-list=WAN
/tool mac-server
/tool mac-server mac-winbox
anav
April 11, 2019, 12:43am
9
You can get rid of this quickset default rule…
/ip dns static
and add some dynamic dns server entries such as 1.1.1.1 or 8.8.8.8 for example.
What is the purpose of this input chain rule? You have it inserted twice in your config as well!
What is the purpose of this forward chain rule?
The issue i currently have is that i cannot seem to ping the other network.
The firewall rules are ones fro the vlan thread that looked like they might help…
Any idea of why it might not be doing intervlan routing
mkx
April 11, 2019, 10:58am
11
It seems that ROS is case-sensitive. So your definition of VLAN interfaces
(using small initial letters of interface names) actually defines different interfaces than then used elsewhere, e.g. in interface list membership
(featuring capital letters of interface names).
The small letters are a comment line.
Would it use the comment line?
