Interconnection between juniper and RouterOS and more...
I want to use my RB2011 to interconnect my firewalls just to tested their. In fact, I want to use my RouterOS as gateway for each firewall type and doing a policy based routing.
I used to use Cisco or Juniper as RouterOS. This is the first one and I found this appliance very kind for the moment (there are a lot of possibilities), but here, I have some difficulties with my spirit and the routerOS. May be because, this is a long time a work with Cisco and Juniper. So
I would like to make a trunk between my Juniper SRX and my RB2011. All seem correct. If I doing a show arp on my Juniper I can found one entry:
00:17:95:dc:49:4f 192.168.81.1    192.168.81.1
192.168.81.1 is normale my SVI on my RB2011
but If I try to ping this IP, nothing to do even if with one a source IP.
I wrote some documentation and I must admit that I’m little bit lost.
May be a little map of what I want to do will be better to understand my objective:
My LAN (cisco switch) ↔ Uplink .60.128/30 <->RB2011 (subnet .60.0/25)(SVI .81.0/24)<-> Uplink L2 Trunk allowed Vlan81<->Juniper SRX
What disrupts me, this is a bridge. By default, there is a bridge, may be because of the Wifi AP…
My entries in my Juniper SRX. This is simple ethernet trunk:
reth0 {
        description Link-to-RouterOS;
        vlan-tagging;
        redundant-ether-options {
            redundancy-group 1;
        unit 81 {
            description VLAN81;
            vlan-id 81;
            family inet {
                address 192.168.81.254/24;
I don’t if this is clear, but I will answer at your questions.
Thank you for your help.
