Hi there all when I connect a linksys router to an RB750 and disable its wireless encryption to use as an access point and then I connect a wired computer and a wireless laptop to as well and then I log in with one or the other then anyone else who logs in is automatically logged in. I’m assuming the routeros only sees everyone who connects to the router as one working user.
How can I get around this problem? I would like so that each user has to log in on their own individually.
Would setting up user manager to act as the radius be the solution?
The linksys should have its DHCP server turened off, and the hotspot port should be plugged into the lAN segment of the linksys. Should not use the linksys WAN port.
