hi all
i need to limit bandwith to an interface but i neet to limit to 30 mb and inteface menu only had 128 to 10 mb limit how can i limit interface ether3 to 30 mb rx an tx
thanks
I would say just set up a simple queue with 30M upload and download and make the target your interface
select 10 mb and overwrite the 10 with 30 ![]()
you an input there whatever u prefer.
input as 30M don`t think will work… instead use 30000
In my config with a simple queue on eth5 it worked like charm - ref.: http://forum.mikrotik.com/t/set-high-priority-for-playing-ut3-mangel-ut3-packets/95439/1
thanks work perfect
