Tring to do a LACP bonding for NAS + ESXi host.
I’m getting on ether24 all the tagged traffic from another switch and I’m using ether23 as the ESXi port with all the VLANs, so I’ve added the ether 23 to ether24 as slave:
[admin@MikroTik] /interface ethernet> print
Flags: X - disabled, R - running, S - slave
# NAME MTU MAC-ADDRESS ARP MASTER-PORT SWITCH
(...) switch1
19 R ether20 1500 6C:3B:6B:0A:F5:4A enabled none switch1
20 ether21 1500 6C:3B:6B:0A:F5:4B enabled ether24 switch1
21 ether22 1500 6C:3B:6B:0A:F5:4C enabled none switch1
22 RS ;;; Trunk Port for ESXI Lab #1
ether23 1500 6C:3B:6B:0A:F5:4D enabled ether24 switch1
23 R ether24 1500 6C:3B:6B:0A:F5:4E enabled none switch1
24 X sfp1 1500 6C:3B:6B:0A:F5:4F enabled none switch1
After that I created the Switching VLAN:
[admin@MikroTik] /interface ethernet switch vlan> print
# VLAN-ID PORTS SVL LEARN FLOOD INGRESS-MIRROR QOS-GROUP
0 D 4095 ether1 no no no no none
switch1-cpu
1 13 ether23 no no no no none
ether24
2 200 ether21 no no no no none
ether23
ether24
[admin@MikroTik] /interface ethernet switch egress-vlan-tag> print
# VLAN-ID TAGGED-PORTS
0 D 4095
1 13 ether23
ether24
2 200 ether23
ether24
Also added the correct egress VLAN tagging and ether23 is working as expected. Also ether21 is working as expected (untagged):
[admin@MikroTik] /interface ethernet switch ingress-vlan-translation> print
0 ports=ether21 service-vlan-format=any customer-vlan-format=any new-customer-vid=200 pcp-propagation=no sa-learning=no
My goal is to have ether19 and ether20 on a LACP bond (802.3ad) but on the other end the device has no VLAN setting (it can have, not sure if works) so it needs untagged traffic.
I’ve tried this on a Cisco Switch and it worked right away. I’m sure I’m missing something.
