Hi, my RB800 with 1 wireless card…
currently it connect to 1 switch (flat, no vlan),
in my setting, i make use of the interface bonding on the ether1 and ether2
and the setting is “active backup”, with mii type 1 monitoring, and the primary interface will be the ether1…
my question is, is that is the correct configuration? and my switch is no setting required?
beside this, if i add one bridge interface, and the bridge port is “bonding1” + wlan1…
any potential issue may happen to this setup?
