interface bonding with SFP+ and Ethernet
i need to make a lacp (bonding) with 1x SFP+ and 2x (1G)Ethernet ports so i want know is it possible that lacp 1x SFP+ and 2x (1G) Ethernet ports on mikrotik ccr 1036 8g 2s+ ?
my next side has cisco nexus 4948 for this,
thanks
For LACP all interfaces must be of the same speed & duplex.
You can use a SPF+ port, but needs to be a SFP (1G) module, and not a SPF+ (10G) module.
You can run SPF (1G) and copper together in a LACP, no problems there.
