Zwodka
1
Hi All!
A would like to connect 2 or more ethernet interface with speed limit.
For example:
- ether1 → ether2 : 10Mbps
- ether1 → ether3 : 20Mbps
- ether2 → ether1 : 30Mbps
- ether2 → ether3 : 40Mbps
- ether3 → ether1 : 50Mbps
- ether3 → ether2 : 50Mbps
How can I do it?
I’ve tried:
- all ethernet ports in 1 Switch plus Simple Queue
and
- all ethernet ports in 1 Bridge plus Simple Queue
Simple Queue:
- Target: ether1 / ether2 / ether3
- Dst: ether1 / ether2 / ether3
without any success
All I know about golden law of queuing (
) you should put the fastest queue in higher priority .
Zwodka
3
Fastest, lowest, higher, lower … doesn’t matter.
I’ve tried it with only one Queue … no success
yancho
4
When bridging set
/interface bridge settings set use-ip-firewall=yes
Zwodka
5
When bridging set
Code: Select all
MegaThanx! It works fine!
What if I have more than 1 Bridge? Does it affect all Bridge?
yancho
6
Yes that is global setting
