Somehow interface ether2 has disappeared from my interface list. The lights still flicker so its active, But where can I add it back into the interface list?
It seems to be you renamed it.
To check default names run next command in Terminal:
/interface ethernet print detail
and find interface with default name ether2.
That is solved thank you. Now ether0 is gone. there are 6 ports. ether0 to ether5.
Is it real routerboard, x86 PC or virtualized?
it is x86
