Interface Flapping
Hi, my problem is similar with the posts bellow:
Jul 18, 2014:
viewtopic.php?t=87134
Feb 08, 2016:
viewtopic.php?t=104622
Feb 16, 2016:
viewtopic.php?t=104899
Jul 02, 2018:
viewtopic.php?t=136376
Apr 05, 2020:
viewtopic.php?f=1&t=159575
Apr 25, 2020:
viewtopic.php?f=13&t=160381
I have a CCR1036-8G-2S+EM with 10GB link with a CRS317 and the sfp’s interfaces are flapping!
The time between those flappings is completely random.
We took some actions to try to fix the situation:
Changed CRS317 for a CRS305 >> still flapping.
Changed gbics and cords >> still flapping
Disabled auto negotiation in both boards >> still flapping
I noticied that only on CRS317 and CRS305 is telling us about interface is going down, when the flap occurs in the log. The CCR1036 don’t pop up not even a warning, except for OSPF going down.
Then we decide to make a bound (LACP) between the CCR1036-8G-2S+EM and the CRS317, because we think that that are much harder two interfaces flap at once,right? Wrong, both sfp interfaces flapped at same time. So, problem not solved.
The CRS317 is a bridge dumb config with bounding:
add admin-mac=74:4D:28:XX:XX:XX auto-mac=no name=bridge1 priority=0x1000
add bridge=bridge1 interface=sfp-sfpplus4 internal-path-cost=2 path-cost=2 \
    priority=0x60
add bridge=bridge1 interface=sfp-sfpplus7
add bridge=bridge1 interface=sfp-sfpplus8
add bridge=bridge1 interface=sfp-sfpplus9
add bridge=bridge1 interface=sfp-sfpplus10
add bridge=bridge1 interface=sfp-sfpplus11
add bridge=bridge1 interface=sfp-sfpplus12
add bridge=bridge1 interface=sfp-sfpplus13
add bridge=bridge1 interface=sfp-sfpplus14
add bridge=bridge1 interface=sfp-sfpplus15
add bridge=bridge1 interface=sfp-sfpplus5
add bridge=bridge1 interface=sfp-sfpplus6
add bridge=bridge1 interface=bonding
CCR1036
add name=loopback0
set [ find default-name=sfp-sfpplus1 ] auto-negotiation=no
set [ find default-name=sfp-sfpplus2 ] auto-negotiation=no
/interface vlan
add comment=LOJA interface=ether8 name=vlan6 vlan-id=6
/interface bonding
add mode=802.3ad name=bonding1 slaves=sfp-sfpplus1,sfp-sfpplus2 \
    transmit-hash-policy=layer-2-and-3
/interface vlan
add interface=bonding1 name=vlan352 vlan-id=352
add interface=bonding1 name=vlan353 vlan-id=353
add interface=bonding1 name=vlan354 vlan-id=354
add interface=bonding1 name=vlan355 vlan-id=355
add interface=bonding1 name=vlan356 vlan-id=356
add interface=bonding1 name=vlan357 vlan-id=357
add disabled=yes interface=bonding1 name=vlan1000 vlan-id=1000
add interface=vlan1000 name=vlan1001 vlan-id=1001
add interface=bonding1 name=vlan1050 vlan-id=1050
add interface=vlan1000 name=vlan1050-1000 vlan-id=1051
add interface=vlan1050 name=vlan1051 vlan-id=1051
add interface=bonding1 name=vlan1051-epon vlan-id=1051
add interface=vlan1050 name=vlan1052 vlan-id=1052
add interface=bonding1 name=vlan_border1_temp vlan-id=3500
add interface=bonding1 name=vlan_border_ipv6 vlan-id=1011
There is any solution? Thank you.
