Hello, MT don’t support USB. But how about ISA? I use ISA Ethernet and the MT didn’t detect it as Interface. I have 5 PCI and 1 ISA, so the MT only detect PCI, only five ethernet. Thanks.
This is an old ne2000 board ?
- Load Winbox.
- Open Drivers window (on left)
- Press the red “+” button.
- Select your card from the list. (if present) (If not get another card as you CANT add drivers to RouterOS)
- Pray there are open resources for your card.
- If 5 is true then you will see the interface the the interface window.
Craig
Thanks, It’s work…
But when I admin@mikrotikint eth pr
There is interface that
R
R
R
R
R
Not Ready? What is the problem? The ethernet is broken or the slot is damaged?
Exactly what card is it?
ISA Ethernet
Possible IRQ conflict, i had a problem with a 3Com ISA and IBM PCI (intel chip) both with IRQ 10, only one card would be running. Look at PCI info.
OK. Thanks… I’ll check it…
